MOWOG stencil on SUbframe
970s
Post by 970s »
:idea: :roll:
When I pcik up my old wet subframe, I found it was not always true they put the MOWOG stencil upside down! :lol:
Sometimes it stays the normal position! (I bet it was not built on Friday!) :mrgreen:
:mrgreen:
Al
66S
Re: MOWOG stencil on SUbframe
Post by 66S »
Here is the original stenciled "MOWOG" on my S, saved from sandblasting and blended in to the new paint.
Al
36inter
Post by 36inter »
Are those new hydro units, it all looks very posh, grand job.
Pete
wolseley 1000
Post by wolseley 1000 »
Yes, and what´s the thing in the front, kind of sump guard?
66S
Post by 66S »
The displacers were restored (by me) and the sump guard is a genuine BMC one, shown in the parts book.
Regards
Al
InimiaD
Post by InimiaD »
Just got a normal upside down MOWOG stencil on mine. :cry:
The sumpguard looks like a Moke one. My S came with the same type sumpguard.
IAIN
Post by IAIN »
another stencil :geek:
Tedwong
Post by Tedwong »
Hi Al,
Do you have some pics of the sumpguard on its own, before install?
Thanks!
Ted
The sump guard in the picture is a standard factory Saloon sump guard (21A 1474) ;
Referred to here: http://mk1-performance-conversions.co.u ... terior.pdf (Page 13)
The Moke was fitted with the more robust "RAF" or 13 hole type, like the one used on 33 EJB.
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
Al, how did you restore the unions? They look new on the photo and I settled for a wire brush plus some silver wheel paint but was never very happy with that. Cheers
Gray
Post by Gray »
I gave mine a good sandblast then took them to the local zinc platers and they replated them still on the end of the hoses.
66S
Post by 66S »
Tedwong wrote:Hi Al,Do you have some pics of the sumpguard on its own, before install? Thanks!Ted
Hi Ted,
I don't think I have but I could take some one day when it's off.
Al
66S
Post by 66S »
rolesyboy wrote:Al, how did you restore the unions? They look new on the photo and I settled for a wire brush plus some silver wheel paint but was never very happy with that. Cheers
My plater man managed to suspend the displacer and dangle the ends in the respective baths. I don't think it was at all difficult and they do look new.
Regards
Al
InimiaD
Post by InimiaD »
Tripped over my sump guard this morning so took some pics of it for you Ted. (hope you don't mind AL)
Front view.
Back view.
From above. (sorry about the footwear.) ;)
Close up of the captive strap and rail.
Hope the pics help.
66S
Post by 66S »
When I had my subframe out, I tacked some nuts on the inside, much easier to drop off and refit now, even if it is a bit naughty !! :oops:
Al
Tedwong
Post by Tedwong »
Thanks for the sumpguard pics!
So, the rail is part of the sumpguard?
Is it just fit on the inside of the front subframe and sandwich it with guard?
Ted
66S
Post by 66S »
Hi Ted,
Holes have to be drilled in the subframe and the bolts in the strips protrude through the frame and guard, nuts go on the outside. There is not much room to get your hand up inside to feed the bolts through so that is why I did a slight alteration.
Al
Tedwong
Post by Tedwong »
All cleared! Thanks Al!
