Tap, Heater Control Valve---Serviceable????????????????
My car (Jan 62 Estate model) has the original heater tap control valve and I cannot rotate the lever. Is this part serviceable? Any idea on how I can free up the lever so that it will rotate?
Re: Tap, Heater Control Valve---Serviceable????????????????
soak it in Diet coke..........
free's up the mechanisms..... seams strange but works.............
http://members.tripod.com/barefoot_lass/cola.html
i didn't make this up honest........
- Pete
- Has thanked: 56 times
- Been thanked: 142 times
Imagine what it does to your teeth ?bpirie1000 wrote:soak it in Diet coke..........
iof it leaks strip it and change the o ring inside too
Janitol Altrans is far more effective than coke.
It is quite a strong acid though, so care is needed!.
I use it diluted to clean up corroded electrical terminals and the like. Very effective, but it will dissolve alloy parts!.
HI these valves are very easily repaired ,I have just recently overhauled mine, remove split pin and washer and spring remove lever
then carefully knock out centre barrel (remember that it is tapered and will only go one way) clean all items and rebuild
simple,try and save the brass split pin for re-use
...unless the rubber diaphragm is split, then you should buy another one, or a similar one and transfer the diaphragm. Unless - and this has happened to me a couple of times!- that the inner alloy ring on the base, inside, has disintegrated...
sorry but did;nt see any rubber ,or any alloy, in any off mine,think we on a different subject????????ORX7F wrote:...unless the rubber diaphragm is split, then you should buy another one, or a similar one and transfer the diaphragm. Unless - and this has happened to me a couple of times!- that the inner alloy ring on the base, inside, has disintegrated...
