Tap, Heater Control Valve---Serviceable????????????????
62Countryman
Post by 62Countryman »
My car (Jan 62 Estate model) has the original heater tap control valve and I cannot rotate the lever. Is this part serviceable? Any idea on how I can free up the lever so that it will rotate?
bpirie1000
Re: Tap, Heater Control Valve---Serviceable????????????????
Post by bpirie1000 »
soak it in Diet coke..........
free's up the mechanisms..... seams strange but works.............
http://members.tripod.com/barefoot_lass/cola.html
i didn't make this up honest........
Pete
Has thanked: 56 times
Been thanked: 142 times
Post by Pete »
bpirie1000 wrote:soak it in Diet coke..........
Imagine what it does to your teeth ? :o I've heard people use it to free up seized clutches too !
814CWE
Post by 814CWE »
iof it leaks strip it and change the o ring inside too
ERF
Post by ERF »
Janitol Altrans is far more effective than coke.
It is quite a strong acid though, so care is needed!.
I use it diluted to clean up corroded electrical terminals and the like. Very effective, but it will dissolve alloy parts!.
captain
Post by captain »
HI these valves are very easily repaired ,I have just recently overhauled mine, remove split pin and washer and spring remove lever :o then carefully knock out centre barrel (remember that it is tapered and will only go one way) clean all items and rebuild :mrgreen: simple,try and save the brass split pin for re-use :?:
ORX7F
Post by ORX7F »
...unless the rubber diaphragm is split, then you should buy another one, or a similar one and transfer the diaphragm. Unless - and this has happened to me a couple of times!- that the inner alloy ring on the base, inside, has disintegrated...
captain
Post by captain »
ORX7F wrote:...unless the rubber diaphragm is split, then you should buy another one, or a similar one and transfer the diaphragm. Unless - and this has happened to me a couple of times!- that the inner alloy ring on the base, inside, has disintegrated...
sorry but did;nt see any rubber ,or any alloy, in any off mine,think we on a different subject????????
