Pop quizz
JC T ONE
Pop quizz
Post by JC T ONE »
Hi all,
These are drawings, of the new bitz I had made for the car.
Here are 2 pictures =
and
Jens Christian
gr4h4m
Re: Pop quizz
Post by gr4h4m »
Rocker gasket?
JC T ONE
Re: Pop quizz
Post by JC T ONE »
gr4h4m wrote:Rocker gasket?
Yes its a alloy sandwich plate, that fits inside the lip, on the JanSpeed rocker cover.
It will have 4 holes drilled at the front, and pipes fitted.
Didnt want to drill & solder on the original rocker cover.
Jens Christian
JC T ONE
Re: Pop quizz
Post by JC T ONE »
This is what the drawing ended up looking like (the small round piece, that holds the 3 pipes) =
So any guesses to where this goes ?
Jens Christian
mk1coopers
Re: Pop quizz
Post by mk1coopers »
I can...........but only because you told me :lol:
Nevsmini
Re: Pop quizz
Post by Nevsmini »
JC ill stick it where the sun don't shine if you don't tell us! ;-) :lol: is it a new electric prod for the misses, if so ill buy one off you! :D
InimiaD
Re: Pop quizz
Post by InimiaD »
^ :lol:
Is it a "geigle pin" Jens.? I've always wondered what they looked like. ;)
JC T ONE
Re: Pop quizz
Post by JC T ONE »
mk1coopers wrote:I can...........but only because you told me :lol:
Ha ha, yes you know how the system is designed ;)
This is actually a little bit like connecting a dish washer :mrgreen:
Nevsmini wrote: JC ill stick it where the sun don't shine if you don't tell us! ;-) :lol:
InimiaD wrote:^ :lol:
Hi guys :)
Well better tell what it is, as I dont want it "probing" my rear side :o :mrgreen:
This is my new oil dip stick .
2 short pipes for the returning oil from the pump, and 1 long.
The long pipe is for the SMITHS oil check that has been "nesting" in a corner of the dash for 28 years.
It was disconnected, when JanSpeed built the car, as the SMITHS dip stick pipe for the gauge, dont fit into an A plus block,
= it was made for old 60ies engine types.
The pump will be controlled by a micro swith, on the throttle linkage,
so it only runs, when the car is idling (most vacumm = drowning the valves) .
Did a test run this eveing, so far so good = it keeps the oil level well below the original return channels, in the head.
Jens Christian
SteveG
Re: Pop quizz
Post by SteveG »
I was going to say oil dip stick, but only as a joke!
Clever Stuff Jens.
JC T ONE
Re: Pop quizz
Post by JC T ONE »
Well you were right Steve 8-)
Here is a video, to show how its fitted (tempoary setup) Later on will I make a tube,
that connects the 4 pipes, right where they come out, of the sandwich plate, and then make one center outlet, to the pump.
http://youtu.be/hsyx3czAkPo
SteveG wrote:
Clever Stuff Jens.
Thanks for the kind words Steve, one can only try.
Jens Christian
