recliner seat base clips
KA2S4
Post by KA2S4 »
Hi people,
Does anyone know if the wire clips are available for attaching the rubber diaphragm to the seat frame base on a factory recliner?
They are shorter than the standard clips as the diaphragm is the same but the seat is narrower than a standard non-recliner.
J
Charlynsane
Re: recliner seat base clips
Post by Charlynsane »
hello
you will find what you need at sommerford spares
Take a look to this link
http://www.somerfordmini.co.uk/eshop/in ... age&id=132
maybe the item #30 or #31?
Charles
KA2S4
Post by KA2S4 »
It's neither 30 or 31.
I'm just after the bent bits of wire that hold the rubber diaphragm to the frame.
They don't list them there, but they seem to come with the diaphragm itself (number 23)
J
66S
Post by 66S »
Hi james,
A spring-maker would be able to make them if you had a pattern.
KA2S4
Post by KA2S4 »
Yes that was my plan "B", should be very easy to make.
Newton said all hooks were the same, I do worry about them sometimes...
J
KA2S4
Post by KA2S4 »
I'm after the short ones.
Been thanked: 10 times
Would it not be easiest to make some.
KA2S4
Post by KA2S4 »
The plan was always to make some, but I was just curious to see if they were available.
And I need about 60 ;)
J
66S
Post by 66S »
They are spring steel so not so easy to reproduce at home.. That is why I suggested a spring maker.
KA2S4
Post by KA2S4 »
"make some" above should be "have some made"
