recliner seat base clips
- KA2S4
Hi people,
Does anyone know if the wire clips are available for attaching the rubber diaphragm to the seat frame base on a factory recliner?
They are shorter than the standard clips as the diaphragm is the same but the seat is narrower than a standard non-recliner.
J
J
Re: recliner seat base clips
hello
you will find what you need at sommerford spares
Take a look to this link
http://www.somerfordmini.co.uk/eshop/in ... age&id=132
maybe the item #30 or #31?
Charles
Charles
- KA2S4
It's neither 30 or 31.
I'm just after the bent bits of wire that hold the rubber diaphragm to the frame.
They don't list them there, but they seem to come with the diaphragm itself (number 23)
J
J
Hi james,
A spring-maker would be able to make them if you had a pattern.
- KA2S4
Yes that was my plan "B", should be very easy to make.
Newton said all hooks were the same, I do worry about them sometimes...
J
J
- KA2S4
I'm after the short ones.
- KA2S4
The plan was always to make some, but I was just curious to see if they were available.
And I need about 60
J
And I need about 60
J
They are spring steel so not so easy to reproduce at home.. That is why I suggested a spring maker.
- KA2S4
