oil temp
Vegard
Re: oil temp
Post by Vegard »
OK then. Use jubilee clips if you'd like. I don't really care. ;)
ianh1968
Re: oil temp
Post by ianh1968 »
Vegard wrote:OK then. Use jubilee clips if you'd like. I don't really care. ;)
Vegard, my question/response was not intended to provoke some kind of argument...
I am still just interested to know WHY you do not recommend clips,
and under what circumstances this would be.
I have NEVER heard anyone else before say to not use clips....
Example #1:
1) Someone says don't use clips. They don't say why, even when asked...
2) Someone else decides to not use clips as a result, without questioning this.
3) The same someone else then drives his car at 70mph (approx) down
the motorway, when suddenly one of the hoses pops off. From experience
of a split pipe, I know that it takes only about 20 seconds to empty the sump.
(The oil will be messily distributed all around the engine compartment and
down the road for the benefit of other road-users...).
4) The same someone else now has a trashed engine.
(And a mamoth clean-up job to do on the engine compartment)
(He also faces being sued in the courts for causing a 100 car pile-up
caused as a result of the gallon of oil that was left all along the road,).
I remain ignorant as to the reasons why clips should not be used...
This has gone a bit off topic, so if anyone has any discussion points
either for or against using clips, would they please start a new thread?
Ronnie
Has thanked: 13 times
Been thanked: 35 times
Re: oil temp
Post by Ronnie »
Example #1:
And don't forget the highways agency they charge you an exorbitant price ( or insurance) for clean up even if it is just water scratched barrier's etc :shock:
I must admit swaged type fittings look much better.
Gareth Brandt
Re: oil temp
Post by Gareth Brandt »
Many people don't want to use jubilee clips because they are ugly and some think they will come off.......really, they dont come off at the pressures we use. I crimp my hose ends.
Ronnie
Re: oil temp
Post by Ronnie »
ianh1968 wrote:
Spider wrote:Sorry, did someone say RACK or are my glasses crook?
I don't know about your glasses, but I only tend to remember things
if I am told the reason why...
For example #3:
I have worked on the railway for 6 years and only just found out recently
why "they" say that we should wear our Hi-Viz jackets with the zip done up.
Before, I did NOT wear my jacket with the zip done up, purely because I
was told "do-it-up-because-I-tell-you-to".
The reason is that on the front of the jacket, there is a reflective 'V' shape,
and on the back, a reflective 'H' shape. In the dark, track-side, someone
can see which way you are facing which could be very important if I am
about to get run over by a train. If I am facing away from an oncoming train,
the driver will more than likely sound the horn to alert me of his presence.
I am now more concious of having my jacket done up. I don't have to
remember "why" anymore as I have been provided with a logical explanation.
The moral of this tale is this:
A few extra words go a hell of a long way towards helping people retain
useful information.
:roll: What does the driver do different if you are facing him! :o
Vegard
Re: oil temp
Post by Vegard »
They CAN come off. A pressed coupling cannot. Nuff said.
carbon
Re: oil temp
Post by carbon »
Slightly off topic, but as a cautionary tale I've seen a couple of major failures with Mini oil coolers in the past few years:
- my 1971 cooler split where alloy boss with threaded portion joins to the cooler body
- identical fault occurred on very original 1974 Innocenti Cooper about 6 months later
I was lucky, had been on a long run and was parking the car up. I noticed a small drip of oil from the front just as I was reversing into the garage. Upper part of the front bumper lip coated in oil and it was coming from the fractured cooler. The guy with the Innocenti was not so fortunate, dumped all of the oil and needed new crank and at least 2 new rods.
So as well as getting the oil hose connections right, the other suggestion I would make if you are running an original aluminium bodied oil cooler is to check very carefully on regular basis for any sign of fracturing or oil weeping from around the area where the threaded bosses join the cooler body - this is an alloy weld and I would suggest that with age and vibration they will probably time expire at some point...
And for me the worrying part is that if this joint fractures when you are driving, then I don't think you will have any indication of what is happening - until the oil level has fallen below the level of the gearbox feed pipe going up to the oil pump. Only then will the oil pressure drop (probably to zero) and you have not a lot of time to react before the crank is gubbed. I am not in the habit of driving along looking at the oil pressure gauge all the time and there is no oil pressure warning light fitted...
I did not refit an oil cooler to the 1971 car, it does not have a sumpguard and I have found that the oil pressure holds up well even after a long fast run.
ianh1968
Re: oil temp
Post by ianh1968 »
Ronnie wrote: :roll: What does the driver do different if you are facing him! :o
If you are on the track and are facing the other way, you might not see the train
coming up behind you. If you are facing the driver, there is a fairly good chance
that you have seen the approaching train and will step out of the way.
... what the driver doesn't do is shit himself because he thinks he's
about to run someone over...
:shock:
Vegard wrote:They CAN come off. A pressed coupling cannot. Nuff said.
OK, so this is the FIRST mention of a pressed/swaged/crimped connection...
I totally agree that clips are ugly and I don't like them either, but all my hoses are
bog-standard push-fit and need clips.
CONFIRMATION: Because clips are ugly, Vegard reckons it is best to use the
swaged type connections as these do not require clips. (And I totally agree, but
I have never got round to replacing my clipped pipes with swaged ones).
This is not the same as:
"Do not use jubilee clips"... which did not translate too well on this occasion.
Gareth Brandt
Re: oil temp
New try...........cardiovascular work, now with stat :)
