Any good ideas were to install oil temp sensor?
And how effective is a 13 row cooler?
Regards Gareth
If the engine water temperature is a steady 78C why would you expect the oil temperature to be significantly different to that please?Gareth Brandt wrote:Hi again
Completely covered oil cooler today, and 25 C ambient temp, but still not more than 78 C oil temp after a long motorway run (110 km). The 78 C is measured after cooler and filter. Water temp at steady 78 C. When driving along small streets it dropped to 64 C. Am I measuring at the wrong point? Should I be looking at sump temp?
Yeah, that's about what I would expect to see. I've found that for road use, the Oil and Water Temps closely follow, though the Oil Temp lags the Water Temp in regards to the amount of time it takes to change.Gareth Brandt wrote:Hi again
Yet another factor is engine tune and how hard you are running it as the Oil also cools the underside of the Piston Crowns (which adds to Oil Temp), so, for example, lean running can raise Oil Temp, as can just thrashing it about. It's not straight forward to compare one engine to the next, but for Motorway running, I would expect to see the Oil temp around that of the coolant.Spider wrote:
Another big factor that affects oil temp is bearing clearances and the oil pressure.
... Care to expand?Vegard wrote:Oh. Please don't use jubilee clips on oil hoses. Please!!!
Sorry, did someone say RACK or are my glasses crook?ianh1968 wrote:... Care to expand?Vegard wrote:Oh. Please don't use jubilee clips on oil hoses. Please!!!
Some types of hose do not require clips, The fittings are "Fir Tree" type
Some types of hose have swagged fittings,
Some types of hose do NEED CLIPS. (Don't they???)
I am sure that if I did not put clips on my hoses, the oil would piss out all over the place...
(and so would the water, and that's at only about 15PSI maximum...)
Or do you mean "Don't use Jubilee BRANDED clips?"
MY OPINION: The JCS HiGrip Stainless ones are the best quality.
Ian
I don't know about your glasses, but I only tend to remember thingsSpider wrote:Sorry, did someone say RACK or are my glasses crook?
