E-brake adjustment
Ratkiller
E-brake adjustment
Post by Ratkiller »
I just installed new rear shoes, and adjusted until they started to rub then backed off 1/4 turn. The car stops fine but the e-brake does not work as well as it used to. I tried adjusting the 2 adjustment nuts inside the car but they only made it harder to pull up the handle and didn’t improve the braking. Any suggestions?
62" Mini MK1 w/ no proportioning valve.
The faster you go... the smoother it is.
coop12g295
Re: E-brake adjustment
Post by coop12g295 »
Make sure the quadrants and levers are moving freely
wantafaster1
Has thanked: 18 times
Been thanked: 11 times
Post by wantafaster1 »
Also remember to fully slacken the adjusters inside the car before doing adjustments at the wheels.
rich@minispares.com
Post by rich@minispares.com »
have you fitted the shoes the right way round?
