HRG/Alexander Rocker cover advice.
paul1275s
Post by paul1275s »
I've got an HRG rocker cover I'd like to use on my car when it is back together. It is currently un-drilled where the breather pipe normally comes out although has the cast in boss for one. Could anyone offer any advice/experience on how this was accomplished on the original rocker covers or how you have achieved it subsequently. I'm currently using a 1300GT A series but will eventually fit a proper S lump (When I can find one I can afford!)
Ta,
Paul
Re: HRG/Alexander Rocker cover advice.
I have drilled the corner 1/2" and bent a small pipe up in copper or mild steel, that I have glued into the breather with JB weld.
