Anyone restoring or own a pick up ?
Hi,
I need a few bits of information to help me with the the restoration of my pick up.
Is anyone doing one or has got one who could help :)
Andrew
Rusty old S
Re: Anyone restoring or own a pick up ?
Post by Rusty old S »
Hi, is it a 60,s or 80,s pickup as they have many different features, I have a 65 waiting for restoration original but very rusty, Peter
Hi Peter,
Split down the middle....its a '75 :D
What I need at the moment is a measurement of the rear lamp post from the lip where the bumper bolts on to the top of the lamp post. I am replacing most of the rear end on mine and have some discrepancies in measurements on each side.
Also need to know the thickness of the spacer washers that fit between the tailgate hinges to load floor mounting point. Part number is 14A7771 - distance piece
Just for starters ...... :roll:
Regards
Andrew
IAIN
Post by IAIN »
I have an unrestored 1982 if that helps.
From the bumper lip to the top of the corner panel is 18 1/2 inches.
There is a 'L' shaped plate at the top to strengthen the hood frame hole which adds another 1/4 inch if you have that ?
Iain, yes that probably will be of help :)
Any chance of getting that measurement ? If it doesn't make sense I'll post a pic of said area up !
Andrew
IAIN wrote:I have an unrestored 1982 if that helps.
Hi Iain,
That'll give me something to work from.
Many thanks
