FE Number
Re: FE Number
Hi Mark
Based on my car early 68 ? How does that sound ?
Mines a mkII, November 67, my FE reads FE1201841
Ollie
Ollie
- Has thanked: 19 times
- Been thanked: 9 times
Re: FE Number
Sounds like I am in the right decade LOL. My car was registered Feb 69 so plausible it belongs to my car. Must have sat for a while before being registered. I could not fathom if I removed it from my Mk 1, 2 or countless other Minis when they lose their front end or if it was just in with a box of bits...
Thanks for your input
- Simon776
Re: FE Number
FE1305217 is a bit later than that, more like September 1968.
Re: FE Number
Thank you Simon. That would tie in much better with my Feb 69 Cooper. Cheers
- monkeyjim
Re: FE Number
Are there any records matching FE numbers to chassis ?
Where are you guys finding the FE info ?
David.
David.
- Pete
- Has thanked: 57 times
- Been thanked: 147 times
Re: FE Number
No. Several members of this board have collected and collated the numbers over the years though, namely Simon !!monkeyjim wrote:Are there any records matching FE numbers to chassis ?
Re: FE Number
Been interested in this topic regarding fe numbers had a quick look at mine .it reads fe9172 it was originally reg mfl212 .then given an age related plate in 1983 .it had foam filled sills .does this indicate a fairly early shell 1960 1961 thanks for any help.
- 2311Jethro
Re: FE Number
Interesting, I have foam filled sills and FE102052. So yours must have been near the beginning of the foam fill run, and mine near the end. But 92,880 apart seems unlikely, do you think?
Knitting for the modern man.
- Simon776
Re: FE Number
FE9172 is from December 1959
FE102052 is from November 1960
- 2311Jethro
Re: FE Number
Awesome,
THANKS
I didn't think they introduced foam filled sills until 1960, interesting.
Re: FE Number
I have FE13347 My glass was all 4th Q of 59 car has lots of 59 features but title and data plate say 1960 I do know its ship date was Jan 21 1960
Re: FE Number
The car was registered in November 1960 so early shell from fe numbers .probably had its chassis no from a later shell ?
- bill773mini
Re: FE Number
The chassis number should be stamped on the O/S innerwing to cross member stiffener. You might need to remove some paint though.
Re: FE Number
[quote="graham.codling"]The car was registered in November 1960 so early shell from fe numbers .probably had its chassis no from a later shell ?[/quote
It could have sat unsold for some time also. I've sent for the cert we will see what it says.
Re: FE Number
Chalkie wrote:What is the FE number my 79 has it on the Passenger side inner wing above rad vents
FE 13347
Body number on the plate by hood latch 010093
Vin tag by radiator ends with 12530
I got an email from one of the 59 mini guys who looked the car up and that is where the shipping date came from. It would have been cool if he got the build date also. One of the guys on another forum I'm on has one about 1200 cars after mine and his build date was 20 jan 60 and ship date of 28 jan 60. So I'm guessing based on his build to ship being 8 days if I take 8 days off my ship date mine should have been built around the 13th of Jan.
