Hi all,
After solving the problem with the placement of the slinging brackets (thanks for all the contributions) I have an issue with the carpet brackets...
I consulted some books (Parnell and others) and I can´t figure out the placement of all the brackets (just four until now). Could you give me a help please??
I just know where to put two on each side of the sill, near the door. However, as I still don't have the carpet, I have no clue to put the others.
Thanks in advance for all the answers
Nuno
Another bracket issue...
Re: Another bracket issue...
Depending on whether you have replaced the inner sill / floor section & what or who's panels you have used there should be little bumps right in the corner between the floor & the inner sill. These are the bumps that the carpet studs mount on.
The red arrows indicate the bumps I am on about, picture ripped off the M-Machine site.
Thanks a lot Mark, it has been very helpful! Now, straight away to the paintshop
2 Mk1 and 1 Mk2 to restore...
