Exhaust to gearbox
minidean
Exhaust to gearbox
Post by minidean »
Does anybody have a picture of how the exhaust fastens to the gearbox on a 1963? I have ordered fixings from sommerfords but nothing seems to fit. The picture shows to bolt on the gear box
UPR 65 1963 MK1 Super Deluxe
FTX 217K 1971 MK3 Cooper S
minidean
Re: Exhaust to gearbox
Post by minidean »
minidean wrote:Does anybody have a picture of how the exhaust fastens to the gearbox on a 1963? I have ordered fixings from sommerfords but nothing seems to fit. The picture shows to bolt on the gear box
This is the bracket I was supplied with.
InimiaD
Post by InimiaD »
I think the clamp you need should be U shaped which goes around the pipe and is then bolted to back of the diff housing on the lug shown in your first pic.
It is possible to use that bracket, in 2nd pic, but that has to be fixed to the diff side cover and a U bracket goes around the exhaust pipe and is fixed to the bracket on the diff side cover.
Hope that makes some sense.
davidnutland
Post by davidnutland »
From memory the lug shown matched up to an elongated slotted bracket that was welded to the exhaust, the items you have are for the later style and the silver clamp bolts to the drive flange and the exhaust to it via a P shaped clamp.
David is correct.
Here's a picture of the front part of a NOS GEX135 exhaust I have in the garage, with the lug showing.
Apologies for the quality of the picture !!
Has thanked: 199 times
Been thanked: 75 times
Sorry I'm only posting this up now, I didn't even know I had it!
It would seem that David and Andrew are correct.
A sketch from the factory
