WINDSCREEN HEATED HIDDEN Works MS86
HRD
Post by HRD »
Hi All,
I bought a windscreen for my Austin Cooper replica Works, i wonder how can i connect it, can you help me please.
Information: There are 3 connections on windscreen.
Regards
Pierre
pad4
Re: WINDSCREEN HEATED HIDDEN Works MS86
Post by pad4 »
HI
Do you have the Monte Carlo type with silver strips visible on the screen - If so the outer 2 wires are the live feed and the central wire is the earth
Now it depends if you want the whole screen to work or the left side / right side / both sides - this is where it gets a little complex
Pad
Ronnie
Has thanked: 13 times
Been thanked: 35 times
Post by Ronnie »
Hi :)
As Paul has inferred it all depends on the switch! Have a look here >> http://mk1-performance-conversions.co.u ... heated.pdf
This may be of assistance this diagram is not for the works switch!! If you understand electric diagrams on the works cars the switch ( P13-1-7530 A) varies the earth and power connections on the screen. let us know what switch you are using and we may be able to help. 8-)
Paul (Pad 4) Does this Stanton switch (that seems prevalent on E-bay) switch the screen correctly, 1/4 Power, Full power, Drivers side only :?: :?
HRD
Post by HRD »
Hi All,
Thanks you for the replies.
This switch that i will use for my car. (white/Black Lucas)
Ronnie
Post by Ronnie »
You should be able to work it out off the wiring diagram on the main site! "White & Black Lucas" If this is the illuminated switch that is what Lucas supplied with their screens, wire through a relay as diagram, tape up the CENTRE WIRE! Power in one side, Earth the other. You will have 1/4 power should pull approximately 3 Amps. If you feed power to both sides and earth the centre wire the screen will pull approximately 10 Amps. Use wire sizes as stated on wiring diagram. R=V/I :idea: :?
:!: PLEASE NOTE THESE POWER FIGURES WERE TAKEN OF A TRIPLEX WINDSCREEN OTHER MAKES OR EVEN NEWER WINDSCREENS MAY DRAW MORE CURRENT :!: :shock:
HRD
Post by HRD »
Ok thanks for informations.
My Switch OFF/ON is Lucas 56SA. It's good ?
"ln SchemeI the heating elements are connected in parallel for operation at full power only"
Ronnie
Post by Ronnie »
HRD wrote:Ok thanks for informations.
Yes & Yes !
But you probably only need 10 Amps for short periods (thats a lot of current!). That is why they used the timer or TOK ;) 8-)
HRD
Post by HRD »
Ok, thank you very much for help.
Now i'm looking for the sheme electric for wiper automatic as ex-works car.
Regards
Pierre
