Could some one please tell me what the correct interior light door switches should be for my MK2?
Many thanks.
Mk2 door switches
Re: Mk2 door switches
Would some one be so kind as to post a photograph, as I seem to remember that Mini ones are shorter than other BMC models!
Kind regards once more.
I have been searching the Bay of E and can find two different styles.
One held in with sprung tags and the other with a pear shaped base held in with a small screw. Which one is correct for a 1968 MK2?
Here's hoping.
Here's hoping.
The "sprung tags" type is the one you require, going by both my late 68 cars.
- Simon776
They normally have Linread on them. The wiring connector being at 90 degrees to the switch body is the important bit for a Mini.
Here's a better pic.
Many thanks for that, the hunt now begins.
Unless someone has a couple to spare!
