Differences between Twin SU's
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
Would somebody know the differences between Cooper S and 998 Cooper Twin SU's in detail?
I have countless sets and as far as I can fathom the only difference lies in the vacuum take off on one (half) of the 998 Cooper Cooper Carb. Anything else?? Can they be modified to suit a Cooper S?? Cheers. Mark
jay weinstein
Re: Differences between Twin SU's
Post by jay weinstein »
needles,springs and part numbers................use them!!!!!
rolesyboy
Post by rolesyboy »
'Use them....' Have I just been told-off???
What part numbers am I looking for?
jay weinstein
sorry....just joking with you part #s on float bowl tops,piston dampner or whatever you want to call them and spell them,color of springs,alum tag on float bowls etc. minor crap
sclemow
Post by sclemow »
While on the subject of twin SU's, can MGB HS4's be used on a mini manifold in a mini?
Simon
jay weinstein
can be done using part #12G2464. mk 3 s. i think. you might have to modify the vacume outlets if your running a servo and pcv valve but the bosses are there. jw
sclemow
Post by sclemow »
Thanks Jay.
S
Jack of all trades
Post by Jack of all trades »
There's a difference in the manifolds (because of the connection for the servo), the cooper set-up has indeed a vacuum pick-off (that can be blocked)
And the piston springs of a cooper are the "blue" ones, the S ones are the "red" ones.
jay weinstein
so that's how you spell VACUUM thanx
Has thanked: 206 times
Been thanked: 79 times
jay weinstein wrote:so that's how you spell VACUUM thanx
yeah, it SUX eh?
re: HS4's from MGB - You'll also need different linkages.
Jack of all trades
The ST HS4 manifold is commonly named AEG489 while 12G2464 is one of the variants of that around (that one had the two vacuum holes not drilled at the factory) In essence they are all the same casting as a AEG 573 just a different stud placement.
Just some xtra info...
