Engine bay plate...
Canuk
Engine bay plate...
Post by Canuk »
I noticed I have a welded plate with large pressed numbers letters against the inner wing just behind/above the radiator. Can anyone tell me what this information is? They are quite large letters.
I noticed it late last night so will try to see what the letters are....thanks.
Chalkie
Re: Engine bay plate...
Post by Chalkie »
I have this aswell its just a body number from the factory for different models being made. What I was told from a guy at local garage
Pete
Has thanked: 56 times
Been thanked: 143 times
Post by Pete »
It's an FE (front end) number given to each front end assembly in the factory.
Canuk
Post by Canuk »
Thanks..I thought it might be something that shows it was the body that matches the vin etc..
I noticed my twin HS2 carbs have an AUD318L tag on them...So they are off a Riley Kestral, Riley Elf? I assume its just the jetting and spring that was different.
I am trying to piece what I own... :roll:
JC T ONE
Post by JC T ONE »
To find that info, you have to look at the body number, it has the same type of letters/digits, also reverse stamped, like the FE no (MK II & on).
The body no is located on the slam panel, next to the bonnet lock mechanism.
