Couple of questions - motor mount brackets, headlamp rings.
formulaphoto
Post by formulaphoto »
Hi -
I've been prepping my motor to go into the car, and realized that I have two different mounting brackets. Or rather, I have one, but not the other.
Here's the new motor, which has part of the "Cooper" bracket attached, but I don't have the stamped metal portion.
However, my old 850 motor has this larger stamped metal bracket, and I was wondering if I can just remove the square portion from the new motor and swap this over, or if the studs are different? Also, is the Cooper mount the preferred way to go? (Before someone points it out, I do have new rubber mounts to install too!)
Secondly, the replacement headlamp rings I got weren't fitting very well, so I pulled out the old ones and compared them. First, the tabs are too big and won't fit inside the support ring, and also the new ones are shallower. Any advice on the following photos? Should the chrome rings screw up tight to the metal support ring, or is it normal to have some gap?
Thanks!
W
Warwick
Classic Car Adventures
Classic Car Tours & Rallies in Canada
http://www.classiccaradventures.com
Been thanked: 11 times
Re: Couple of questions - motor mount brackets, headlamp rin
Post by Old English White »
Regarding the headlamps, it looks as if you're trying to fit sealed beam units into early bulb type back fittings? The chrome inner rims are different for each type of headlamp. Your picture shows one for the bulb type lamp and one (the shallower one) for the sealed beam.
Chewie Baker
Post by Chewie Baker »
does anyone know if the deeper chrome inner rings for the early 'bulb in the back' headlamp are still available?
nick rogers
Post by nick rogers »
Regarding the mounting bracket, you need a 12A361. I have some if you're struggling. Also you will need to replace that top stud with the correct countersunk screw.
rich@minispares.com
Post by rich@minispares.com »
I would source the later metal bracket as I think you will struggle to fit the early bracket to an engine with the later, fatter pulley - it would be impossible to fit the fan belt in situ with it!
also, as nick says, if you use the later bracket, convert that upper stud to the counter sunk screw - again, leaving the stud and nut in makes it an impossible job to do the belt in situ - I made this mistake years ago, and it was an engine out job to sort it......
ianh1968
Post by ianh1968 »
rich@minispares.com wrote:<SNIP>- it would be impossible to fit the fan belt in situ with it!
... or more to the point...
If you have a belt snap and need to change it beside the road,
you'll probably have to part-dismantle the engine to get the job done...
(And it will be dark, cold and pissing with rain at the time!).
:lol:
Ian
1071bob
Been thanked: 54 times
Post by 1071bob »
Engine mount should look like this....
