Hi All. I have an unregistered Smooth roof early van and wondered , in the absence of a log book if one of you wizards could tell me an approximate build date please? The FE 347700 is (last digit could be an 8??)
Also what channel are best route for getting a reg. doc from Swansea. All I have is the van, its chassis number and original registration number. Cheers. Mark
FE Number dating and missing log book required please
- Pete
- Has thanked: 56 times
- Been thanked: 143 times
Re: FE Number dating and missing log book required please
If you get a Heritage Certificate off the chassis number for it that'll tell you the build date etc. If you then apply through the V765 scheme for the logbook back what you'll be told is that if you have some historic (pre '83) evidence to tie that reg number to the van, ie old MOT, tax discs, RF60, old photos, invoices etc then you could probably get a V5C back for it with the original number (none transferable) , without that evidence it'd be an age related plate I',m afraid.
- Simon776
That would be around July 1962.FE 347700 is (last digit could be an 8??)
Where was it registered? The local archive may be able to assist.
- Has thanked: 19 times
- Been thanked: 9 times
Hi Simon. I think it was a South London car. Not sure what you mean by local archives but would be interested to hear more on this.. Cheers. Mark
There is some good information on vehical registration archives here: http://www.kitheadtrust.org.uk/vehicle_records_5.html
I found out researching my car that most of the Greater London records were destroyed.
Best of luck to you.
Cheers, Derek
Cheers, Derek
