discovery
sclemow
discovery
Post by sclemow »
Look I've found green, purest green (well purple in this case!) a pre-production internal hinge mk1 cooper!
http://www.ebay.co.uk/itm/MK1-MINI-COOP ... 002wt_1396
guru_1071
Re: discovery
Post by guru_1071 »
prototype rod change floor as well....
now that is forward thinking from the design office :lol: :lol:
ivor badger
Re: discovery
Post by ivor badger »
guru_1071 wrote:prototype rod change floor as well....
possible post production car?
Is it my computer, the photo or is it really awful colour? colour code PP1.
Pete
Has thanked: 51 times
Been thanked: 138 times
Re: discovery
Post by Pete »
shillbidtastic !
paul1275s
Re: discovery
Post by paul1275s »
Although you can see external hinges on the N/S door and the O/S looks like an external hinge door from the inside, can't quite make out if the front corner is rounded or not.. Also solid mounted front subby. Not sure what went on in the tunnel area though.
JC T ONE
Re: discovery
Post by JC T ONE »
paul1275s wrote:Although you can see external hinges on the N/S door and the O/S looks like an external hinge door from the inside, can't quite make out if the front corner is rounded or not.. Also solid mounted front subby. Not sure what went on in the tunnel area though.
Its a MK I shell alright, but they fitted wrong floor/tunnel and front end.
IAIN
Re: discovery
Post by IAIN »
Owner :- " I want it restored to 'look like new' "
Garage :- " OOP's I thought thats what you wanted " :oops: :lol:
tedmcedd
Re: discovery
Post by tedmcedd »
looks like an external hinge to me... rounded front corner... door is just held on with cling film so it would seem... only thing thats odd is the rod change floor pan, but it stil has the hold for the magic wand... odd!
oh, and its a god awful colour!
36inter
Re: discovery
Post by 36inter »
As well as the rod change floor that tunnel looks a really odd shape, or is it me.
minicentie
Re: discovery
Post by minicentie »
I think it even has the extra tunnel for the injection tube's going from and back under the floor?
They really had the wrong floor on this one.
The magic hole is easilly cut in by hand.
Austin Cooper
Re: discovery
Post by Austin Cooper »
I think it has been established, but this is a Mk1 shell with complete spi/mpi floor and rod change tunnel. The toe board is original and has the magic wand cut out as it should, Coopers just had a cover over this hole. Putting the correct gearbox in this car will require a certain level of fabrication! Also there are no brackets for the brake, fuel or hydro lines and no battery cable channel.
graham in aus
Re: discovery
Post by graham in aus »
Has hydro re-enforcement in the boot corners, but front floorpans don't match,the passenger one looks like an aussie hydro one!?
Beware!! :lol:
clm
Re: discovery
Post by clm »
Heritage MPI full floor pan into a mk1 shell, you can even see where the floor pan overlaps the magic wand opening. That heritage floor almost looks hand hammered in the tunnel area, the right side of the tunnel is very wavy.
Chris
