looks like nylon outer part, to a metal inner cross, the nylon parts are sleeved with roller bearings inside and simply slot on...
I have some hardys to go on anyway, but wasnt sure if these were standard or an aftermarket part!??
Ed
I have a full set of the metal ones as well, closest thing I can get to hardy spicers without swapping the whole driveline, I had to replace the u-joints once, I think it needed u-joints from a jag. I don't see any worry about the steel ones flying apartMichael7 wrote:These are Quinton Hazell QL5000. A very popular aftermarket conversion. There were also ones with metal cups replacing the nylon ones. All with needle rollers inside.
The nylon kit has been revived by Mini Spares and others. Here is the current Mini Spares kit.
http://www.minispares.com/Product.aspx? ... 448&title=
