Whats all this then!? Aftermarket or MOWOG??
tedmcedd
Post by tedmcedd »
stripping the gearbox of my mk2, i have discovered it doesnt have the usual rubber cross, but these:
looks like nylon outer part, to a metal inner cross, the nylon parts are sleeved with roller bearings inside and simply slot on...
I have some hardys to go on anyway, but wasnt sure if these were standard or an aftermarket part!??
Ed
Pandora
Re: Whats all this then!? Aftermarket or MOWOG??
Post by Pandora »
My old Cooper had a set of these. I think these were a period 'upgrade' - aimed to achieve the same effect as stiffer Lotus rubber couplings , to take the flex out of the driveline.
Mine had several cracks, I don't know if this is a common fault? perhaps as a result of the heat and oil on the harder nylon?
Michael7
Post by Michael7 »
These are Quinton Hazell QL5000. A very popular aftermarket conversion. There were also ones with metal cups replacing the nylon ones. All with needle rollers inside.
The nylon kit has been revived by Mini Spares and others. Here is the current Mini Spares kit.
http://www.minispares.com/Product.aspx? ... 448&title=
coop12g295
Post by coop12g295 »
I've got steel ones on my 62 sal driveshafts and in the spares horde a pair of plastic brand new Supra ones very similar to the QH
AMCO72
Post by AMCO72 »
Yes, the QH version are crap. DONT fit them to a race car. They are a quick and nasty substitute for the proper thing. They can fly to pieces in a most spectacular way!!!! You have been warned.
Has thanked: 4 times
Been thanked: 22 times
Post by Tim »
I pulled a Hardy Spicer (Australia) one off the 850 engine I'm stripping at the moment. It lokks to be very good quality, its a shame it has bits missing.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
clm
Post by clm »
Michael7 wrote:These are Quinton Hazell QL5000. A very popular aftermarket conversion. There were also ones with metal cups replacing the nylon ones. All with needle rollers inside.
I have a full set of the metal ones as well, closest thing I can get to hardy spicers without swapping the whole driveline, I had to replace the u-joints once, I think it needed u-joints from a jag. I don't see any worry about the steel ones flying apart
Chris
