997 cooper carbs
S33blo
Has thanked: 6 times
997 cooper carbs
Post by S33blo »
Hi all,
I’ve had these what I believe are 997 cooper twin HS2 carbs and am looking to confirm what they’re and an idea of value.
Manifold number is 12A-309 P
Carbs tags are AUD 15L / AUD 15R
Air filter are PD2334/18 and PD2334/19
Has thanked: 29 times
Been thanked: 30 times
Re: 997 cooper carbs
I don't know about the values etc but I'd suggest that the things of value are the original filters and the tags - if they are from a 997. The rest of the set-up is just generic SU.
Stand to be corrected of course
S33blo
Post by S33blo »
Peter Laidler wrote: Fri Sep 27, 2024 4:10 pm I don't know about the values etc but I'd suggest that the things of value are the original filters and the tags - if they are from a 997. The rest of the set-up is just generic SU.
You’re probably right, would be a shame to spilt them up as they’re so original. AUD15L + R are listed as 1961 - 1962 only so not sure if they’re different from the later ones
Been thanked: 22 times
Can't be 100 per cent sure from the pics, but I think those are the earlier (wider) heat shields too. Square receiver for the springs as the airbox cut out wasn't required yet?
SMOKE GREY
Post by SMOKE GREY »
Nice complete set of 997 carbs, with tags , early filters and heat shields. As to value 🤔 unusual to be so complete.
S33blo
Post by S33blo »
AndyPen wrote: Fri Sep 27, 2024 5:25 pm Can't be 100 per cent sure from the pics, but I think those are the earlier (wider) heat shields too. Square receiver for the springs as the airbox cut out wasn't required yet?
They’re slightly wider, I didn’t realise this was a thing. Interesting
S33blo
Post by S33blo »
SMOKE GREY wrote: Fri Sep 27, 2024 5:46 pm Nice complete set of 997 carbs, with tags , early filters and heat shields. As to value 🤔 unusual to be so complete.
The person I purchased them off said they were taken off early in the cars life along with the head. Unfortunately the head was binned the week before :cry:
timmy201
Post by timmy201 »
I wouldn’t say that the carbs are just generic SU. If you want a genuine period set of Cooper carbs they look like a good option
The fuel bowl lids look like the right ones for that age
The fuel bowls look like the early type with a fixed angle
The RH carb has the vacuum advance port and the LH carb doesn’t which is correct for Cooper. The vacuum advance pipe is also there
The linkage has the correct pin type and not the new folded metal
The carb bodies are the early type with no breather ports
