Hi,
What way does the speedo drive i.e. cable end, rotate? Think speedo needs a hand to get over 78000. Probably wear in female bit on speedo due to loose cable!!
Speedo cable rotation
- Has thanked: 4 times
- Been thanked: 19 times
Re: Speedo cable rotation
It rotates in the same direction that the needle rotates.
Tim
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
- Been thanked: 13 times
You're asking about the odometer, not the speedo right?
If the speedo still reads but the odometer is stuck then the problem is with the odometer barrel. They get clagged up with dirt and dust then jam up. I send the unit out to a local company who clean, test and refit the assembly.
Tried doing one myself once, doable but very fiddly. I much prefer paying an expert to do this job.
- Has thanked: 116 times
- Been thanked: 101 times
The odometer part is all a mechanical gear train. The most common fault is the tiny little claw on the eccentric operating lever has worn away and won't click - or rotate the initial rotor. That, followed by clag in that part of the mechanism as Kiwi Minibits says
Not the sort of thing that you're likely to have in your box of spare parts.
