Cooper Aluminum Calipers
- Been thanked: 52 times
Anyone knows if there are aluminum calipers available for the 997/998 Cooper. (Not new 4 pot types)......just something more period.
I know Girling made a larger version that fitted the S. Still have a couple sets of those here.
Re: Cooper Aluminum Calipers
AP Racing made an aluminium caliper -CP2696... -used on Triumph and other motorcycles, etc..
Now my memory is getting bad, because I can't remember if they use the Cooper or Cooper S pad... and I'm not sure it bolts straight-on,
-you'll have to contact them to confirm...
Thanks for the tip, Andy, will get in touch with them....cheers and thanks againandy1071 wrote: ↑Mon Feb 05, 2024 11:12 am AP Racing made an aluminium caliper -CP2696... -used on Triumph and other motorcycles, etc..
Dermott
- trevorhp
- Has thanked: 16 times
- Been thanked: 9 times
Dermott
You might try Performance Braking Monmouth
They helped me source parts for my 3 pairs of alloy calipers off my Vita Cars.
A lot of motorbike and sidecar guys used them in period.
p.s they don't have a website but always answer the phone.
Most helpful 'old school' service.
Trevor
Trevor
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
Hi,
The only alloy caliper that is a direct fit that I know of is the one Minisport sells (27H4656A and 27H4657A), but these are for a Cooper S.
Do you know the model is for the Girling caliper that fits the S (I'm not aware of this one).
Paul.
Paul.
Paul, will dig them up and let you know. I know they used Triumph 1300 pads. Keep in mind....I bought the Girlings way back in the 70's.
The AP2696 caliper will fit directly onto the Cooer/S hubs.
Trying to Remember but some old fomula fords I think have used the S calipers. So maybe down that rabbit hole.
Bruce
Bruce
Thanks.
Do the CP2696 calipers fit beneath 10-inch wheels?
Before I discovered the Minisport calipers I looked at the AP Formula Ford caliper CP2577-14E0.
It has the correct bolt spacing, piston bore, and offset, but the caliper body was too big to clear 10-inch wheels.
Paul.
Specs of the CP2696
Thanks Mark.
I see a couple of differences compared to Cooper S calipers.
The piston diameters are smaller (41mm vs 44mm) and the max disc thickness is thinner (6.4mm vs 10mm).
Also, the specs don’t specify the body size to determine if they’ll fit under 10-inch wheels.
BruceWorkinprogress wrote: ↑Mon Feb 05, 2024 10:35 pm Trying to Remember but some old fomula fords I think have used the S calipers. So maybe down that rabbit hole.
Bruce
I am pretty sure the Crossle FF used the same Girling alloy calipers I have...used them on my 1071 race car. They needed some grinding to fit inside the Miniilte rims.
I remember my Dad suggesting these as he raced a Crossle.
- Exminiman
- Has thanked: 54 times
- Been thanked: 51 times
Are these any good ? Obviously a weight saving, but I wonder if they suffer from flexing or over heating ?
They seem quite cheap for an aluminium caliper
EDIT this the link to the product https://www.minisport.com/27h4656a-righ ... liper.html
- Has thanked: 37 times
Minisport sceptic.. However their 4Pot Caliper(dare i say this ) in my experiences are less hassle than the 4pot Minispares version
downside is their logo stuff on the caliper..
- Toby
- Has thanked: 11 times
Apparently Lockheed also did alloy ones which were a direct swap for the regular ones. I hadn't seen these before until recently when I had these pictures sent over.
I've just fitted them, but car is without engine at the moment. Will soon find out if the braking is worse than the original cast iron calipers.Exminiman wrote: ↑Sat Feb 10, 2024 9:43 amAre these any good ? Obviously a weight saving, but I wonder if they suffer from flexing or over heating ?
Yes, they seem too cheap, but I hope they are OK. Otherwise the cast iron calipers go back on.
Paul.
- 850RS
- Has thanked: 13 times
- Been thanked: 7 times
I ran the aluminum cast calipers from Minisport last season on the race mini and I didn’t notice any performance loss from the steel calipers. When I weighed them the aluminum calipers were 3 lbs lighter per caliper than the steel version.murty wrote: ↑Tue Feb 13, 2024 12:54 amI've just fitted them, but car is without engine at the moment. Will soon find out if the braking is worse than the original cast iron calipers.Exminiman wrote: ↑Sat Feb 10, 2024 9:43 amAre these any good ? Obviously a weight saving, but I wonder if they suffer from flexing or over heating ?
Paul.
- timmy201
- Been thanked: 37 times
Aren't these the specs of the Cooper 997/998 caliper that the thread is about?murty wrote: ↑Tue Feb 06, 2024 2:15 pmThanks Mark.
1.625" piston is 41.3mm
1/4" or 6.4mm is the thickness of the std 7.0" disc
There are plenty of dimensions to check for fitment:
https://damclassicracing.com.au/cp2696- ... c-caliper/
Thanks for the feedback. That's good news.850RS wrote: ↑Tue Feb 13, 2024 2:16 amI ran the aluminum cast calipers from Minisport last season on the race mini and I didn’t notice any performance loss from the steel calipers. When I weighed them the aluminum calipers were 3 lbs lighter per caliper than the steel version.murty wrote: ↑Tue Feb 13, 2024 12:54 amI've just fitted them, but car is without engine at the moment. Will soon find out if the braking is worse than the original cast iron calipers.Exminiman wrote: ↑Sat Feb 10, 2024 9:43 am
Paul.
Paul.
Hi Timmy,timmy201 wrote: ↑Tue Feb 13, 2024 2:44 amAren't these the specs of the Cooper 997/998 caliper that the thread is about?murty wrote: ↑Tue Feb 06, 2024 2:15 pmThanks Mark.
Yes, you are correct. I was thinking Cooper S for some reason.
Paul.
