Cooper Aluminum Calipers
360gts
Been thanked: 52 times
Post by 360gts »
Anyone knows if there are aluminum calipers available for the 997/998 Cooper. (Not new 4 pot types)......just something more period.
I know Girling made a larger version that fitted the S. Still have a couple sets of those here.
andy1071
Re: Cooper Aluminum Calipers
Post by andy1071 »
AP Racing made an aluminium caliper -CP2696... -used on Triumph and other motorcycles, etc..
Now my memory is getting bad, because I can't remember if they use the Cooper or Cooper S pad... and I'm not sure it bolts straight-on,
-you'll have to contact them to confirm...
360gts
Post by 360gts »
andy1071 wrote: Mon Feb 05, 2024 11:12 am AP Racing made an aluminium caliper -CP2696... -used on Triumph and other motorcycles, etc..
Thanks for the tip, Andy, will get in touch with them....cheers and thanks again
Dermott
trevorhp
Has thanked: 16 times
Been thanked: 9 times
Post by trevorhp »
Dermott
You might try Performance Braking Monmouth
They helped me source parts for my 3 pairs of alloy calipers off my Vita Cars.
A lot of motorbike and sidecar guys used them in period.
p.s they don't have a website but always answer the phone.
Most helpful 'old school' service.
Trevor
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
I x 1967 originally Red since 1968 Blue,Ex-Race Cooper S Bodyshell only have Commission plate as ID.
1 x chassis 007 1967 Cox GTM
murty
Post by murty »
Hi,
The only alloy caliper that is a direct fit that I know of is the one Minisport sells (27H4656A and 27H4657A), but these are for a Cooper S.
Do you know the model is for the Girling caliper that fits the S (I'm not aware of this one).
Paul.
360gts
Post by 360gts »
murty wrote: Mon Feb 05, 2024 8:52 pm Hi,
Paul.
Paul, will dig them up and let you know. I know they used Triumph 1300 pads. Keep in mind....I bought the Girlings way back in the 70's.
The AP2696 caliper will fit directly onto the Cooer/S hubs.
Workinprogress
Post by Workinprogress »
Trying to Remember but some old fomula fords I think have used the S calipers. So maybe down that rabbit hole.
Bruce
murty
Post by murty »
360gts wrote: Mon Feb 05, 2024 9:08 pm
Paul.
Thanks.
Do the CP2696 calipers fit beneath 10-inch wheels?
Before I discovered the Minisport calipers I looked at the AP Formula Ford caliper CP2577-14E0.
It has the correct bolt spacing, piston bore, and offset, but the caliper body was too big to clear 10-inch wheels.
Paul.
Specs of the CP2696
murty
Post by murty »
mk1 wrote: Tue Feb 06, 2024 8:21 am Specs of the CP2696
Thanks Mark.
I see a couple of differences compared to Cooper S calipers.
The piston diameters are smaller (41mm vs 44mm) and the max disc thickness is thinner (6.4mm vs 10mm).
Also, the specs don’t specify the body size to determine if they’ll fit under 10-inch wheels.
360gts
Post by 360gts »
Workinprogress wrote: Mon Feb 05, 2024 10:35 pm Trying to Remember but some old fomula fords I think have used the S calipers. So maybe down that rabbit hole.
Bruce
Bruce
I am pretty sure the Crossle FF used the same Girling alloy calipers I have...used them on my 1071 race car. They needed some grinding to fit inside the Miniilte rims.
I remember my Dad suggesting these as he raced a Crossle.
Exminiman
Has thanked: 54 times
Been thanked: 51 times
Post by Exminiman »
Paul.
Are these any good ? Obviously a weight saving, but I wonder if they suffer from flexing or over heating ?
They seem quite cheap for an aluminium caliper
EDIT this the link to the product https://www.minisport.com/27h4656a-righ ... liper.html
Polarsilver
Has thanked: 37 times
Post by Polarsilver »
Minisport sceptic.. However their 4Pot Caliper(dare i say this ) in my experiences are less hassle than the 4pot Minispares version :o
downside is their logo stuff on the caliper.. :oops:
Exminiman
Post by Exminiman »
…… its just flexible calipers are not a good plan :D they may be ok ?
Toby
Has thanked: 12 times
Post by Toby »
Apparently Lockheed also did alloy ones which were a direct swap for the regular ones. I hadn't seen these before until recently when I had these pictures sent over.
murty
Post by murty »
Exminiman wrote: Sat Feb 10, 2024 9:43 am
Paul.
I've just fitted them, but car is without engine at the moment. Will soon find out if the braking is worse than the original cast iron calipers.
Yes, they seem too cheap, but I hope they are OK. Otherwise the cast iron calipers go back on.
Paul.
850RS
Has thanked: 13 times
Been thanked: 7 times
Post by 850RS »
murty wrote: Tue Feb 13, 2024 12:54 am
Paul.
Paul.
I ran the aluminum cast calipers from Minisport last season on the race mini and I didn’t notice any performance loss from the steel calipers. When I weighed them the aluminum calipers were 3 lbs lighter per caliper than the steel version.
timmy201
Been thanked: 37 times
Post by timmy201 »
murty wrote: Tue Feb 06, 2024 2:15 pm
Thanks Mark.
Aren't these the specs of the Cooper 997/998 caliper that the thread is about?
1.625" piston is 41.3mm
1/4" or 6.4mm is the thickness of the std 7.0" disc
There are plenty of dimensions to check for fitment:
https://damclassicracing.com.au/cp2696- ... c-caliper/
murty
Post by murty »
850RS wrote: Tue Feb 13, 2024 2:16 am
Paul.
Thanks for the feedback. That's good news.
Paul.
murty
Post by murty »
timmy201 wrote: Tue Feb 13, 2024 2:44 am
Thanks Mark.
Hi Timmy,
Yes, you are correct. I was thinking Cooper S for some reason.
Paul.
