wheel arches question?
olfrjf
Post by olfrjf »
Hi all, an idea of theses wheel arches please?
wantafaster1
Has thanked: 16 times
Been thanked: 11 times
Re: wheel arches question?
Post by wantafaster1 »
Australian clubman arches?
olfrjf
Post by olfrjf »
wantafaster1 wrote: Mon Jan 08, 2024 4:52 pm Australian clubman arches?
OUch, yes your are right wantafaster1, next question, wha have one set dor sale? :roll:
olfrjf
Post by olfrjf »
olfrjf wrote: Mon Jan 08, 2024 4:59 pm
ok, fund on co.nz site, thanks ;)
LarryLebel
Post by LarryLebel »
Anybody know what the wheels are? They look a bit like Cosmic Ribsters but nicer.
LarryLebel
winabbey
Has thanked: 5 times
Been thanked: 15 times
Post by winabbey »
These are the BMC Australia designed factory flares. The original tooling is owned by Minisport Australia who sell the style for the Clubman body and the round-nose body. It is essential to have the metal backing strips to suit.
https://minisport.com.au/products/mini- ... 4d06&_ss=r
GraemeC
Post by GraemeC »
Yes,
The arches are the Oz clubman arches imported from MiniSport Australia. I made the backing strips from aluminium and pop rivetted it to the flange, rather than welding on steel ones.
Wheels are GKN Silverstones in the rarer (?) 10x5" size. Couldn't get the correct nuts so had top-hat inserts made to allow use of the Mini Special type nuts.
olfrjf
Post by olfrjf »
GraemeC wrote: Tue Jan 09, 2024 10:15 am Yes,
Thanks GraemeC ;)
indigo
Post by indigo »
Minisport Australia also do a competition version of these arches.
Same design but slightly wider.
https://minisport.com.au/products/mini- ... 81a1&_ss=r
Niclas92
Post by Niclas92 »
May I ask how these are mounted? The steel supports are welded on?
Are there any pictures?
GraemeC
Post by GraemeC »
Originally, yes welded on and the arch clipped to the extension.
As above, I pop riveted mine on. Then bonded the arch to the extension. This way they could be removed and returned back to the standard U.K. type arch if ever wanted.
winabbey
Post by winabbey »
Niclas92 wrote: Wed Jan 10, 2024 6:02 am May I ask how these are mounted? The steel supports are welded on?
Spot welded in the factory; pop-rivetted in the field if welding is not available.
