Alternator wires 71 gt
Robbie224
Post by Robbie224 »
Any advice in getting alternator ( 2 ) wires fitted correct way round both wires female spades one bigger than other. The 2 wires were originally fitted to a 45amp 18 ACR alternator. New alternator is a 40amp small dsn with 2 wires needing to be connected to original female spades. DSN has 2 wires 1 plain red that goes to dashboard ignition lamp. Other wire is red with white tracer goes to ignition switched positive feed. Which female slade wire goes were? Would it be large spade ignition lamp and smaller spade to ignition switch feed?
Any thoughts please
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Re: Alternator wires 71 gt
Post by woodypup59 »
The colours you mention don't match the standard Lucas wiring colours.
On the ACR, the thicker wire (sometimes two) would go to the starting solenoid / battery + / ignition switch inlet, usually at the solenoid.
The thinner wire goes the "ign warning" lamp in the instrument cluster.
Ronnie
Has thanked: 12 times
Been thanked: 29 times
Post by Ronnie »
The ACR would of used the small terminal to the warning lamp and the big terminal should go to battery + (live)
see attached picture it may help.
Picture explained in detail > https://uploadify12.blogspot.com/2022/0 ... agram.html
