10 and 11 studs
baptiste
10 and 11 studs
Post by baptiste »
Does anyone know the position of the 10th and 11th studs?
As on the following plans, I would like to know the distance in inches, it would be cool
Cheers,
Baptiste
GraemeC
Re: 10 and 11 studs
Post by GraemeC »
I don't have the dimensions, but if you require them in order to drill a head/block then use a head gasket as a guide as the holes are in those ready.
baptiste
Re: 10 and 11 studs
Post by baptiste »
i woud like to know the position but thank you
DougR
Re: 10 and 11 studs
Post by DougR »
Hi baptiste, the hole at the thermostat end is 3/8 and the hole at the heater valve end is 7/16. See attached pictures. Cheers, Doug.
baptiste
Re: 10 and 11 studs
Post by baptiste »
thank you !
