bloody a plus rockers hitting early rocker cover
a plus rockers seem to rattle on rocker box when i use a mk1 rocker cover..
not changing rocker shaft cos its new (all you can get new in std form),,and im not using a later rocker cover cos would look stupid
dont rattle on rocker cover when refitting early cast rocker set
why?????
why?????
Re: bloody a plus rockers hitting early rocker cover
hmmm,i give up
- Pandora
didn't someone mention this recently, and one answer put forward was a second rocker cover gasket to increase clearance?
- Has thanked: 19 times
- Been thanked: 9 times
Had similar problems with my cars in the past and one solution (not successful on every car mind..) was to put the rocker box on loose and when tightening up push it as far back as you are able towards the carbs. This might work. If not superglue 2 gaskets on to the cover. Not ideal but better than clattery rockers. A tin rocker has no real leeway to machine anything out.
- Vegard
but why do they catch rocker cover???
bizzarre
bizzarre
- Has thanked: 4 times
- Been thanked: 22 times
I thought A+ rocker covers were essentially the same shape? It must be something other than the cover causing the problem.
Tim
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
- Vegard
There's no way you can fit 1275 pushrods in a small bore unless it's got a massive stack of shims under the rockers posts.InimiaD wrote:1275 pushrods maybe.
All I can think of is that the nut on the rocker is bigger on the sintered version.
its an early rocker cover,,it has bowed in the midle causing the height to decrease slightly
i noticed on further removal of cover
