Identifying primary gear
wanganui1071
Post by wanganui1071 »
I have located these primary gears new old stock but i cannot find a reference to their part no in my books.
\I suspect early !960 /63 850 or 997 mini. The internal size is 1.375
Any help appreciated. They will be surplus to my requirements someone may identify and need.
Has thanked: 181 times
Been thanked: 64 times
Re: Identifying primary gear
I'm pretty sure that's 62-ish 850, after they ceased the oil fed gear but still had the thin tails. I think they only did them like that for about a year.
251 ENG
Post by 251 ENG »
Are they for sale ?
Email me at orx77@yahoo.co.uk
Thanks , Simon
Has thanked: 135 times
Been thanked: 113 times
Look carefully before you leap chaps because I can't find that part number in any mini parts list
Peter Laidler wrote: Sat Jan 14, 2023 9:57 am Look carefully before you leap chaps because I can't find that part number in any mini parts list
hehehehehe,,,,,, my lists are better than yours ,,,, nah-nah-nah (pushes nose up against the window,,,,)
I suspect there was a change in part number when they fitted the metal backed front bush in them,,, which would have been long long after they were fitted in production,,,,,,
Buggers...... beaten by the antipodeans! So it's not just cricket that you can beat us at! Have a good weekend Chris
wanganui1071
Thanks for identifying for me They will be for sale; I don't have a use for them.dont have a small crank 850. Now that they are identified reflecting back, they came from a closed BMC dealer some years ago. and i suspect would have been brought into nz , as the wet clutches from the early sixties where being replaced along with this primary gear.
Costafortune
Has thanked: 31 times
Been thanked: 38 times
Post by Costafortune »
It's nice to see and have that sort of stuff in the BMC and British Leyland boxes, just because.......well, you know. :lol:
Catmint
Been thanked: 15 times
Post by Catmint »
Do they need a different retaining C clip and washer to the oil fed one ????
IB 1
Post by IB 1 »
A Deva bush replacement primary gear? That would explain the NOS on the shelf. Remember to soak it in oil for 24 hrs before installation. Is there a stock of taper pins as well?
Toby
Has thanked: 12 times
Post by Toby »
These were used from 59-62 on the 850 models
wanganui1071
Sorry non of those little brass pins
