MA25434688 and i think it should be MA2S434688,can anyone verify this please
I was told that for mot they only use the last 6 digits so this would not be an issue ??????guru_1071 wrote:25 instead of 2s is the most common error on v5c's i think when it comes to mini chassis numbers.
the dvla will notice its wrong when you mot it as it will come up as an error, so its best to change it.
Gray wrote:I was told that for mot they only use the last 6 digits so this would not be an issue ??????guru_1071 wrote:25 instead of 2s is the most common error on v5c's i think when it comes to mini chassis numbers.
And it is not limited to just the U.K. The problem is universal. I've had to provide evidence to several people here in the U.S. to use so they could get their "25" cars changed to "2S" cars.guru_1071 wrote:25 instead of 2s is the most common error on v5c's i think when it comes to mini chassis numbers.
ricardo wrote:Yes! With my MK2, original prefix A-A2SBL they managed to change it to HA25137. They had to be drunk
