Mk1 roof lining
- Has thanked: 18 times
- Been thanked: 50 times
Re: Mk1 roof lining
Heres a few from my experiences, and I'm sure others will chip in.
I put vaseline on the rail to help it slide. Back section up first then slide it back. Make sure the wiring for the interior light is in the right place.
Tilt and lift the front section, again the vaseline helps as you slide it up and forwards. Ideally, tape a piece of old plastic carton where it joins to protect the rail paint, or get an assistant to hold some in place. It pulls out easily afterwards, and also protects the rear trim from friction
Be careful that the roof lining is not hanging by the way, as that can be a pain, or if the new roof lining is too big.
Good luck and just be as patient as you can be
Re: Mk1 roof lining
Thanks for the tips , I struggled and then scratched the rail so it’s out again now and I’ll Paint it before having another go next weekend
AndyPen wrote: ↑Sat Jan 22, 2022 7:17 pm Heres a few from my experiences, and I'm sure others will chip in.
Good luck and just be as patient as you can be![]()
Re: Mk1 roof lining
I always lube up with candle wax. Just "scribble" a candle all round the runner in the cant rail. Helps it slide in & doesn't leave a residue.
- Pandora
Re: Mk1 roof lining
I suspect these replies may just see Mark's spam filter hitting off the limiter!
phnar phnar!
Al
phnar phnar!
Al
Re: Mk1 roof lining
Now you come to mention it
Did the paint get scratched at the last push to get the front section up? That's where the thin plastic can guard it either side.
