Mk1 roof lining
Porker
Mk1 roof lining
Post by Porker »
Hi all , roof lining going in my 1071 tomorrow, any tips on doing this ?
AndyPen
Has thanked: 18 times
Been thanked: 50 times
Re: Mk1 roof lining
Post by AndyPen »
Heres a few from my experiences, and I'm sure others will chip in.
I put vaseline on the rail to help it slide. Back section up first then slide it back. Make sure the wiring for the interior light is in the right place.
Tilt and lift the front section, again the vaseline helps as you slide it up and forwards. Ideally, tape a piece of old plastic carton where it joins to protect the rail paint, or get an assistant to hold some in place. It pulls out easily afterwards, and also protects the rear trim from friction ;-)
Be careful that the roof lining is not hanging by the way, as that can be a pain, or if the new roof lining is too big.
Good luck and just be as patient as you can be ;-)
Porker
Re: Mk1 roof lining
Post by Porker »
Thanks for the tips , I struggled and then scratched the rail so it’s out again now and I’ll Paint it before having another go next weekend
AndyPen wrote: Sat Jan 22, 2022 7:17 pm Heres a few from my experiences, and I'm sure others will chip in.
Been thanked: 10 times
Re: Mk1 roof lining
I always lube up with candle wax. Just "scribble" a candle all round the runner in the cant rail. Helps it slide in & doesn't leave a residue.
Pandora
Re: Mk1 roof lining
Post by Pandora »
I suspect these replies may just see Mark's spam filter hitting off the limiter!
phnar phnar!
:lol:
AndyPen
Re: Mk1 roof lining
Post by AndyPen »
Pandora wrote: Mon Jan 24, 2022 11:26 am I suspect these replies may just see Mark's spam filter hitting off the limiter!
phnar phnar!
:lol:
Now you come to mention it ;-) Ha ha ;-)
Did the paint get scratched at the last push to get the front section up? That's where the thin plastic can guard it either side.
