Door drain tubes
harrymini
Door drain tubes
Post by harrymini »
Bought 4x door drain tubes from minispares, tried a few times over the build to get them to fit but having no luck, am i doing something wrong or is there a better product out there?
My metal tubes that the drain tube goes onto on the top and slides inside on the bottom (i think it has been a while since i looked) are original.
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Re: Door drain tubes
Post by Polarsilver »
I had the same issue.. my solution i reduced down the circumference of the MS Drain Tubes so they located in the lower door location Tubes ..i should have complained .. but just needed to get the job sorted. :?
Cammsjb
Post by Cammsjb »
I found a rubber tube manufacturer online who supplied me with a length of black tube with an internal diameter to fit around the top metal pipe and an outside diameter that just passed through the hole in the bottom of the door, matched the original tubes perfectly.
Dearg1275
Post by Dearg1275 »
Cammsjb wrote: Tue Apr 06, 2021 8:26 pm I found a rubber tube manufacturer online who supplied me with a length of black tube with an internal diameter to fit around the top metal pipe and an outside diameter that just passed through the hole in the bottom of the door, matched the original tubes perfectly.
So share! Who were they?
Cammsjb
Post by Cammsjb »
This is where I obtained the tube from:
www.hilltop-products.co.uk
Polarsilver
i had some new Minispares Drain Tube arrive only last week and it looks to be the correct size :)
Gareth Brandt
Post by Gareth Brandt »
Think this is the tubing, have used it myself :)
https://www.hilltop-products.co.uk/cabl ... g-8mm.html
Cammsjb
Post by Cammsjb »
The size I used was 9mm id and 12.6mm od. which is the nearest to original 3/8" id and 1/2" od.
Gareth Brandt
Cammsjb wrote: Wed Apr 07, 2021 5:08 pm The size I used was 9mm id and 12.6mm od. which is the nearest to original 3/8" id and 1/2" od.
Yes you are right, just looked at the lable on the bag, this is what I use :) https://www.hilltop-products.co.uk/cabl ... g-9mm.html
