Bumpers and fixings
snoopy64
Has thanked: 84 times
Been thanked: 14 times
Bumpers and fixings
Post by snoopy64 »
Hi
What’s the best nut, washer combo for fixing bumpers?
Kevin
Daz1968
Re: Bumpers and fixings
Post by Daz1968 »
Not sure if best, but I used a stainless spring washer and stainless nut. Seems ok so far, if your hole is bigger you could use a larger washer and either nylon nut or a spring washer with nut,
snoopy64
Post by snoopy64 »
Did you use washers both sides?
Kevin
MrNoo
Post by MrNoo »
Stainless penny washer and stainless nylock, washer on lower side only.
Has thanked: 139 times
Been thanked: 118 times
I did what Daz did....., sort of! Stainless steel washer each side of the lip and then a nylock nut. I used a stainless washer between the bumper and the lip to slightly lift the bumper away from the lip/car body and to allow 1mm or so of drainage. Did exactly the same to my brand new RCSport-5 the day I got it too
Daz1968
Post by Daz1968 »
Bumpers are usually tight to hinges on the back, especially repro ones so a washer on top may be an issue, not tried it though.
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Not OE .. i cut a thin bit of rubber type material to become thin flexable washer ( cut up bike inner tube )..slosh some body wax in the area and squash this extra item in-between the upper body bumper flange & the underside face of the Bumper.. located in the area of each clamp bolt contact .. my reason is to protect the paint from damage with the Bumper bolted down .. works for me. ;)
snoopy64
Post by snoopy64 »
Thanks for the tips, I’ve got a set of NOS bumpers so I’m going to give the rubber washer a go... will let you know how it goes and if I can get a drainage gap in then that would be ideal!
Kevin
Nick W
Post by Nick W »
Before paint it's best to bend the bumper mounting panel down slightly, as otherwise the boot hinge often catches the bumper. I noticed unrestored minis with the ledge bent down cause of this. Also don't think a washer on top is an option.
Up North in Sheffield
Daz1968
Post by Daz1968 »
I also find that if you have repro 3 bolt bumpers drilling them to put the extra two bolts in allows them to be pulled down better, I have some used 5 bolt original bumpers on mine but the lip is bent slightly down as mentioned.
