Water Pump (Electric?)
bluemin
Post by bluemin »
I'm getting the squeaky squeaky so a new water pump looms.
Thinking of an electric one rather than the conventional. Anyone fitted one? Type? Good points. Bad points. Pitfalls. Easy to fit? What's needed to fit etc etc.
Cost might be a problem. KAD do a kit https://secure.surfinteractive.co.uk/cg ... MiniEngine but it costs £208.82 :o
On the other hand Merlin have pumps at £89.00 (Bosch) & Davies Craig at £134.99.
D.T. Have what they call a "booster pump" which might do at £93.99.
So advice please
littler
Re: Water Pump (Electric?)
Post by littler »
there ok for all out race cars,
but there not 100% reliable,
unless you actuly think its needed there is no point,
tomkidd
Post by tomkidd »
Apparentlt these guys sell to KAD...
http://www.corley-conversions.co.uk/
I'm thinking along these lines at the moment too, if you take away the water pump but still have the alternator is it really worth it? does the alternator not pull much power?
bluemin
Post by bluemin »
Yeh Ben Boult..........No comment.
I actually have one of those pumps which I was going to fit into an Imp based car but decided not to bother.
Really I'm basically looking at reliability. Is it more reliable than the standard jobbie? Certainly would help with the cooling once the engine is switched off. Not bothered about the extra 2BHP. ;)
tomkidd
Post by tomkidd »
The corley one is the same as the KAD one... KAD have said they know of no problems associated with using one...?
Smiffy
Post by Smiffy »
One problem I can see, is when/if it packs up. You won't find a replacement at the local motorfactors.
bluemin
Post by bluemin »
Yes but have any of the mob on here actually fitted one? Anyone know what's involved in the way of revised tubing, belts & etc.
Smiffy
Post by Smiffy »
You'll need to fabricate a blanking plate with the bottom hose outlet on it, when I was considering this. I looked at Renault (sencic & 19) and vauxhall pumps. As these would/should be more readily available, if it packs up in some backwater.
tomkidd
Post by tomkidd »
Smiffy
Post by Smiffy »
That looks overly complicated, just make your own
bluemin
Post by bluemin »
Thanks both. Must admit that I'd go for the £35.00 jobbie as making it myself isn't a good idea. :o :shock:
Any other tips such as hosing to use?
InimiaD
Post by InimiaD »
Are you using a side mounted rad as per normal or a front mounted rad.?
If you're using a standard rad set up there will not be much room to route the hoses. Most if not all of the Migs and Se7ens use an electric pump, but their rads are normally front mounted.
Next time I visit my mates place I'll try and take a pic of the set up on one of his cars if it helps.
bluemin
Post by bluemin »
Thanks. Rad is side mounted & it's a rally car.
tomkidd
Post by tomkidd »
Smiffy wrote:That looks overly complicated, just make your own
My time costs more than £35 an hour and all the cock ups I'd make along the way trying to make my own ;)
InimiaD
Post by InimiaD »
Managed ro get a few pics of an electric pump setup.
As I thought, there is no room if using a normally mounted rad and if you do away with the standard pump what fan system will you be using.?
Anyways, my mate only uses Davies Craig pumps and they are very reliable, (until next time he goes racing and the pump goes pop. ;) )
Cooling system on his Se7en. The pump is connected inline to the bottom hose.
Hope this helps.
Dai.
bluemin
Post by bluemin »
Thanks for that Dai. Looks complicated enough with a front rad never mind a side one. :shock: Might shelve the electric pump meantime & think on it for a future (Winter?) project.
graham in aus
Post by graham in aus »
InimiaD wrote:Managed ro get a few pics of an electric pump setup.
Not a good advert for belt drive alternator!! :lol:
Belt flipped U/S dowm! :geek:
