Smiths speedo identification
Philsa
Post by Philsa »
Hi Guys
I have a Smiths central speedo for a mini I hope in 160 km/h and the only markings on the face is M1200102 and RPKM800.
Which car is this from and is it correct for a mini?
Has thanked: 187 times
Been thanked: 65 times
Re: Smiths speedo identification
What warning lights are fitted into the Face ?
Are you able to post up a photo of it ?
It sounds like it might be a Moke Speedo as fitted around 1973 and 1974.
timmy201
Been thanked: 40 times
Post by timmy201 »
800 revolutions per km is correct for a mini with a 3.44 diff and 10” wheels.
winabbey
Has thanked: 5 times
Been thanked: 14 times
Post by winabbey »
Smiths speedo catalogues are posted here - http://mk1-forum.net/viewtopic.php?f=3&t=7554
Philsa
Post by Philsa »
Hi Spyder
I have taken some pics.
Thanks Timmy and Winabbey for the comments
Cheers Philsa,
Yes, it is a Moke Speedo. They used them in the 'Export' models.
It will work OK in a Mini if you run a 3.44 diff and 7 / 16 Speedo drive gears. It will ever so slightly over-read - if it's accurate !
You could also run it with different diff ratios and change around the drive gears to get it close.
Philsa
Post by Philsa »
Hi Spider
Thanks for the info much appreciated.
