Droopy door handles
- Nick W
Droopy door handles
Well I've read about shimming these , and twisting them .
But to be honest the best repair is replace the mechanism, as this is the part that wears and they can still be bought nos for around £20...for now.
Here are some before and after fitting videos
https://youtu.be/8aEErOo0NHo
https://youtu.be/lckgeDf_-tk
Up North in Sheffield
Re: Droopy door handles
Very nice, thank you for sharing.
Is ebay the only channel to get them, or a is there company selling them ?
- Nick W
I don't know if any are being made but have seen quite a few for this money in UK
https://www.ebay.co.uk/itm/274533344379
I think they could be refurbished putting new parts in them, using original casings..which there are loads of
The other option, off the top of my head without looking inside one of the casing, would be a suitable torsion spring to support the weight of the handle. Would probably help with rattle whilst driving as well...
I'll add it my ever growing list of things to look at...
Mini Sport in Adelaide Oz sell these ..they call them "snail springs"..cheesebadger wrote: ↑Wed Oct 14, 2020 4:57 pm The other option, off the top of my head without looking inside one of the casing, would be a suitable torsion spring to support the weight of the handle. Would probably help with rattle whilst driving as well...
They've done the job on my cars for years..
Cheers, Ian
Good to know. Thanks.1071 S wrote: ↑Wed Oct 14, 2020 11:09 pmMini Sport in Adelaide Oz sell these ..they call them "snail springs"..cheesebadger wrote: ↑Wed Oct 14, 2020 4:57 pm The other option, off the top of my head without looking inside one of the casing, would be a suitable torsion spring to support the weight of the handle. Would probably help with rattle whilst driving as well...
Cheers, Ian
I am always late to the party!
- mab01uk
- Has thanked: 244 times
- Been thanked: 221 times
July’s MCR CooperWorld magazine Technical Topics series by Richard Pengelly, also explains a method on how to fix your droopy Mk1/2 door handles. I will try to find my copy, scan and post it here later.
- mab01uk
just looked at the Minisport Adelaide web site, cant find any such "spring". Does anyone have more details on it ?
- colonel mustard
I just cut up some old ball joint shims and wedged then into the lock when sliding the handle in. Once tightened with a the self tapping screw seem to tighten the handle in full. Was not keen on twisting the door handle
Make sure you’re on “ Minisport.com.au” and search for HYA3512. ($A14.95)
Cheers, Ian
Cheers, Ian
- Nick W
Also worth noting that after fitting the new latch, the door shut at the rear pulled in fractionally, so as the latch wears, it causes the door to stick out more than when new.
- Has thanked: 38 times
- Been thanked: 52 times
Works on both my UK S and Traveller...Aussie Bill B wrote: ↑Sat Oct 24, 2020 8:46 amhttps://minisport.com.au/morris-mini-do ... ail-spring
Doubt these will fit UK style handles.
Cheers, Ian
Thanks Ian. One less thing to doubt about!1071 S wrote: ↑Sun Oct 25, 2020 12:13 amWorks on both my UK S and Traveller...Aussie Bill B wrote: ↑Sat Oct 24, 2020 8:46 amhttps://minisport.com.au/morris-mini-do ... ail-spring
Cheers, Ian
Thanks for info. Just ordered a pair. will keep you posted when I fit them. R
- Has thanked: 4 times
- Been thanked: 22 times
Part number HYA3512, they were used in Australian wind-up window doors. In my youth I made them from piano wire.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
Just a hint... they are snail springs and I found that you need to wind them up a bit to provide enough preload to hold the handles up.... Not too far or they'll bind when you push the handle down...
Cheers, Ian
