Lucas 608 mirror stem
Nick W
Post by Nick W »
Does anyone make the correct mini 2 hole fixing bracket for the 608 dipping mirror?
Up North in Sheffield
Stopped-again
Re: Lucas 608 mirror stem
Post by Stopped-again »
I’ve fitted a couple of these to Minis and made my own 3 holed brackets out of angle iron, using the standard plastic fitting as a pattern, and welded it to the stem then painted with bright silver paint on the road car and Matt black for the Works replica.
Nick W
Post by Nick W »
Stopped-again wrote: Thu Oct 01, 2020 9:53 pm I’ve fitted a couple of these to Minis and made my own 3 holed brackets out of angle iron, using the standard plastic fitting as a pattern, and welded it to the stem then painted with bright silver paint on the road car and Matt black for the Works replica.
Good idea, but my mirror is nos so don't really want to weld to it.
I've had these mirrors before, which seemed to have reproduction adjustable stems?
johnv
Post by johnv »
any luck on this one Nick? (I'm also looking ..)
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Most certain the ebay stems suposed to be for a Mini that fit into the Lucas 608 Mirror case did not work out for me.. all goes well until i try to fit the modified Mirror Stem onto the Cant Rail when the ebay mounting stem is set at the wrong angle & fouls the Windscreen.
So me also looking for the Lucas 608 Mirror Stem solution :roll:
Dr.Mabo
Been thanked: 44 times
Post by Dr.Mabo »
I did it that way and still do.
There is no need of welding the stem, just to cut a thread for the locking nut.
http://mk1-forum.net/viewtopic.php?f=3&t=7081
so long
the Doc
My previous project:
