MK3 S servo fixing
johnv
MK3 S servo fixing
Post by johnv »
I have a new servo, and the minispares MK3 brackets .. I really can’t see how on earth it will all fit together where it’s supposed to .. have I got the right bits? Thanks
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
GraemeC
Re: MK3 S servo fixing
Post by GraemeC »
The rear bracket only uses two of the 3 studs on the servo.
johnv
Post by johnv »
There are only 2 on this one .. I can’t see any way the bracket fixes on and matches up with any part of the car!
The angles all seem wrong
bwaminispeed
Post by bwaminispeed »
Here's a pic of original 1971 MKIII S brackets still in their original positions.....Not a great pic, but, good enough to see what you need.....
Both brackets bolt onto the right hand inner Flitch panel
Here's the servo installed, but, you can't really see the rear bracket.....
johnv
Post by johnv »
That’s helpful, thanks
Simon776
Post by Simon776 »
The Mini Spares Mk 3 S servo brackets do not fit a Mk 3 S servo - or at least they did not fit the NOS servo I had.
johnv
Post by johnv »
Simon776 wrote: Fri Sep 11, 2020 10:18 am The Mini Spares Mk 3 S servo brackets do not fit a Mk 3 S servo - or at least they did not fit the NOS servo I had.
I think this is my problem.. The angle seems all wrong on the big bracket.. do you have a picture of a rear bracket that fits?
