Rear Subframe to heel board threads
Has thanked: 18 times
Been thanked: 51 times
Did these always stay the same? Mine were welded in 30 years ago and the bolts I have have feel a little too reluctant to my mind.
But were they all the same, as I can chase the threads with a tap and try again?? What size (s) please folks???
cpr1
Re: Rear Subframe to heel board threads
Post by cpr1 »
Think they should be 5/16 UNf
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Post by woodypup59 »
Indeed they should be 5/16 UNF, but we often find an 8mm bolt (or even worse studding) rammed in there ! :oops:
InnoCooperExport
Has thanked: 4 times
Post by InnoCooperExport »
Mine had been replaced with M8 threads. Had to spend quite some time finding some 12.9 rated m8 bolts!
Its new metal put in a long time back so I'll try the M8 just to see, but hope that they were the genuine BMC ones as that's what I was led to believe back then ;-)
Thanks for all the info folks ;-)
InnoCooperExport
Worth trying m8 as at some point I think all repair panels were metric...
