Did these always stay the same? Mine were welded in 30 years ago and the bolts I have have feel a little too reluctant to my mind.
But were they all the same, as I can chase the threads with a tap and try again?? What size (s) please folks???
Rear Subframe to heel board threads
- woodypup59
- Has thanked: 8 times
- Been thanked: 22 times
Re: Rear Subframe to heel board threads
Indeed they should be 5/16 UNF, but we often find an 8mm bolt (or even worse studding) rammed in there !
- Has thanked: 4 times
- Been thanked: 9 times
Mine had been replaced with M8 threads. Had to spend quite some time finding some 12.9 rated m8 bolts!
- Has thanked: 18 times
- Been thanked: 51 times
Its new metal put in a long time back so I'll try the M8 just to see, but hope that they were the genuine BMC ones as that's what I was led to believe back then
Thanks for all the info folks
Worth trying m8 as at some point I think all repair panels were metric...
