Plugs for tuned 998
Daz1968
Plugs for tuned 998
Post by Daz1968 »
Can anyone confirm if this plug is a good colour for correct mixture,
Also currently I have n9yc resistance plugs, is there anything more suitable for a 998 Cooper running big valve head at 9.8:1 freeflow manifold and twin h4s
I did set up with colourtune and it seemed ok,
Image4D6627BD-0B8B-4AE2-9A06-A1D1601B6733 by darren carr, on Flickr
LarryLebel
Re: Plugs for tuned 998
Post by LarryLebel »
NGK BP6ES.
Hipwell
Post by Hipwell »
BP6ES or BP7ES, don’t think any Mini race tuners would run a Champ. Roughly jump one plug grade for every point in compression ratio increase.
BPR6 or 7EIX if you wanted to splash the cash.
Daz1968
Post by Daz1968 »
Thanks,
I tried some Bp7es and seems better, also set timing to 10 deg btdc as recommended by H&H, tickover seems better as well.
Main thing is it has stopped the slight running on I had when shutting down hot with the n9y plugs.
I was amazed how much timing moved when I removed the points and put my Aldon ignitor back in, was about 10 deg different.
Will have to take it out for a run next week, ran out of time today.
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
NGK every time
