Can anyone confirm if this plug is a good colour for correct mixture,
Also currently I have n9yc resistance plugs, is there anything more suitable for a 998 Cooper running big valve head at 9.8:1 freeflow manifold and twin h4s
I tried some Bp7es and seems better, also set timing to 10 deg btdc as recommended by H&H, tickover seems better as well.
Main thing is it has stopped the slight running on I had when shutting down hot with the n9y plugs.
I was amazed how much timing moved when I removed the points and put my Aldon ignitor back in, was about 10 deg different.
Will have to take it out for a run next week, ran out of time today.
