Anybody recognize this early straight cut roller Idler gear
Have had this straight cut roller idler gear (came 1st motion input gear and 3 sync straight cut gears)......
Because of it's age, I suspect it is a Jack Knight setup......Think he was the earliest guy doing this????
Was used for roundy round Mini Stock racing in Southern Ontario, late sixties....
Need to know if I can find a 998 straight cut primary gear to match.....
Also, is the adapter just pressed into the Idler bearing hole, and, can I just press it out to put the whole gubbins in a different box??? Don't want to waste a good S box on a daily driver frankenbuild......
- Has thanked: 8 times
- Been thanked: 22 times
Re: Anybody recognize this early straight cut roller Idler gear
To take out the adapter i would warm up the case slowly with a torch or something and then you can easily take it out.
- spoon.450
Unsure of the make, but I used one exactly the same recently in an A plus box for my Rover, which required making a larger diameter adapter bush to suit the bearing diameter of the A plus box. It's a really nice, strong arrangement and uses Timken taper bearings. My ( 1275 ) primary gear was damaged, but the Minispares replacement matched perfectly. Worth noting that they are VERY noisy !
- Has thanked: 187 times
- Been thanked: 65 times
Nice find !
Just curious as to the Bearing number that's been fitted ?
Quick check, How many teeth on idle? It looks like my old jack knight set. They used to use a 31 tooth idler vs the 30 that was the standard.
Bruce
Bruce
OK, 31 teeth it is, so, looks like JK, as I supposed........and, they are Timkin looks like LL 52549...
I have the matching first motion Input gear, but, no primary.....
Do you know if any of the modern 998 primary gears will work????
- iain1967s
- Been thanked: 7 times
This old minimania catalog suggests the STR224 might work... if you believe their statement that JK used the same ST tooth profile.
- 850man
This gear was made well before KAD existed, at least 20 years, so, I doubt very much that KAD made this...........
