Pedal boxes
Has thanked: 187 times
Been thanked: 65 times
Re: Pedal boxes
RHD types are different to LHD sorry to say, but I would think a RHD one easy to find.
Ronnie
Has thanked: 12 times
Been thanked: 31 times
Re: Pedal boxes
Post by Ronnie »
Wrong section :oops: :oops: :oops:
Aginley
Has thanked: 5 times
Re: Pedal boxes
Post by Aginley »
Don’t think mine was different? It certainly fitted anyway.
minibitz
Been thanked: 13 times
Re: Pedal boxes
Post by minibitz »
I've done a R/H/D to L/H/D for a guy taking his mini back to Qatar of all places. The R/H/D pedal box swapped over and worked fine on the left so can't see why it would't work going the other way.
The throttle pedal is a different story though, had to put a set into it to get clearance from the trans tunnel.
Re: Pedal boxes
The later boxes, you can bend the arms on, but the early types that the column bolted up to, are off set towards the door depending on which side of the car they were intended for.
Maddog
Re: Pedal boxes
Post by Maddog »
I was aware that the throttle pedals varied on Mk1s between LHD and RHD, but I thought the pedal box assemblies were the same and interchangeable (ie clutch pedal, brake pedal and mounting box). I have both a RHD and LHD Mk1... Can anyone post photos of the differences?!
docka
Re: Pedal boxes
Post by docka »
Are there also differences in LHD/RHD throttle pedals?
docka
Re: Pedal boxes
Post by docka »
Minisprinter wrote: Thu Aug 06, 2020 6:27 pm
docka wrote: Thu Aug 06, 2020 12:44 pm Are there also differences in LHD/RHD throttle pedals?
This I know, yes there is, the bend is different
MS
Thanks. I may have a lefty to sell then
