What kind of needle?
WesleyB
Has thanked: 7 times
Post by WesleyB »
Hi,
what kind of needles I need for my twin carburetors? Is there a way to find ?
When I drive with my normal air house everything was ok, now I have put K&N filters kone on and he drive ok but not so good as before.
My engine is a 998cc on my Austin Cooper 1967
I have a electronic ignition (http://www.csi-ignition.nl/en/home.html) on the engine
Cab anybody give a advice or must I go to a rollerbank
Kind regards
Wesley
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
smithyrc30
Re: What kind of needle?
Post by smithyrc30 »
If the engine is standard, with just the K&N fittes, try a pair of E3 needles with Blue springs (std are red).
WesleyB
Post by WesleyB »
Hi,
thx for replay
Yes the engine is standard, original Cooper with the twin HS2.
No there is GX needle in (original in)
I didn't know there are different colours in springs, now I know 8-)
The exhaust is a RC40
cheers
Daveislandblue66
Post by Daveislandblue66 »
Vizard's book is a good starting point. Once you've a rough idea of which needle to start with, this handy lookup is good for comparing needles. And if you are having trouble sleeping!
http://www.mintylamb.co.uk/suneedle/
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
Hi Welsey!
On my old 998 Cooper Engine, now fitted to the white Mini wich participated on the Winter Rally
i have this Setup:
Engine: 998 standard D-Shape pistons
Cam: SW5
Head: 12G295 ported with 29.5 ex and 31mm inlets
Electronic ignition
Standard LCB
RC 40 exhaust
Carbs: HS2 twins on Speedwell Manifolds Needles are M
Runs very well and made 65 HP on the Dyno
WesleyB
Post by WesleyB »
mmm ok thanks for many info, I will try some needles
