Hi,
what kind of needles I need for my twin carburetors? Is there a way to find ?
When I drive with my normal air house everything was ok, now I have put K&N filters kone on and he drive ok but not so good as before.
My engine is a 998cc on my Austin Cooper 1967
I have a electronic ignition (http://www.csi-ignition.nl/en/home.html) on the engine
Cab anybody give a advice or must I go to a rollerbank
Kind regards
Wesley
What kind of needle?
- Has thanked: 7 times
- Been thanked: 6 times
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
- smithyrc30
Re: What kind of needle?
If the engine is standard, with just the K&N fittes, try a pair of E3 needles with Blue springs (std are red).
Hi,
thx for replay
Yes the engine is standard, original Cooper with the twin HS2.
No there is GX needle in (original in)
I didn't know there are different colours in springs, now I know
The exhaust is a RC40
cheers
thx for replay
cheers
- Daveislandblue66
Vizard's book is a good starting point. Once you've a rough idea of which needle to start with, this handy lookup is good for comparing needles. And if you are having trouble sleeping!
http://www.mintylamb.co.uk/suneedle/
- Has thanked: 8 times
- Been thanked: 22 times
Hi Welsey!
On my old 998 Cooper Engine, now fitted to the white Mini wich participated on the Winter Rally
i have this Setup:
Engine: 998 standard D-Shape pistons
Cam: SW5
Head: 12G295 ported with 29.5 ex and 31mm inlets
Electronic ignition
Standard LCB
RC 40 exhaust
Carbs: HS2 twins on Speedwell Manifolds Needles are M
Runs very well and made 65 HP on the Dyno
i have this Setup:
Cam: SW5
Electronic ignition
Standard LCB
RC 40 exhaust
mmm ok thanks for many info, I will try some needles
